How do I get some lift in the rear?
Thanks Tom, it makes sense to keep the cut-off valve in the open position unless as you have indicated I need to isolate that bag for repair or other.
However, it sounds like having the Schrader valve and cut-off valve in their current configuration won't be much help, so perhaps I should consider
reversing them, at some point.
Thanks Johnny, good point on testing the position of the valve arm.
Regards,
Mike
When you do reverse the valves, I would suggest you mount them on the wall of the wheel well with a short line to the bag.
Less jounce.
Don Adams Dallas, TX
'76 26' Glenbrook, '90 Sidekick
rebuilt by R Archer, powered by J Bounds, Koba
"]http://www.gmcmhphotos.com/photos/data/6109/G2.jpg[/IMG][/url]
