I have always used the std battery that GM put in (I think they call it a
D8) - until now. Most of our club members run a pair of golf batteries. So I
followed the advise of the vast majority (about 2:1 in our club).
The "D8" is a large battery designed to "START" big trucks. It has a lot of
cranking power but no sustaining power. It is also not designed to discharge
completely and then recharge. If you use your coach more than 2 or 3 times a
year the D8 will wear out quickly. Mine were lasting less than 2 years.
Most in the club get 4 to 5 years out of the golf style. Some longer.
I got mine at Sam's for $42 each and the D8 at Sam's is $79. So price about
the same. You will need a couple of extra cables. Get the heaviest ones you
can. I took my old positive in and they matched it for size. Got mine at
Discount Auto. They were in stock and cheap.
In my 78 Eleganza - the ground cable was long enough, then I needed a 12" to
connect the 2 golf batteries (+ to -), and I needed a longer positive cable
as the original would not reach with the new setup. I got a 24 inch one.
Over all a pretty easy install. Now I plan to add the xtra two batteries I
bought in the rear.
There is also some wasted space between the rear battery compartment and the
rear of the coach. Enough for 2 more golf batteries if you wish.
You have to access from inside and under the left goucho in the std GMC
setup.
FYI
Mike Finnicum
78 Eleganza
74 Stretch
bought in the rear.
setup.
FYI
Mike Finnicum
78 Eleganza
74 Stretch
