Holley 650 CFM double pumper
gary j zingle
326
"I checked the Holley and found it to be a 4165 List 0-6497 which is the
direct street replacement for the 455 (non Tornado) Mechanical
secondaries, spread bore, double pump, 650 cfm, emmisions carb, integral
choke. I have the Holley book so I can identify anyones carb if they so
desire.
Is the carb with it's 650 cfm okay for the coach? What cfm was the
original?"
While a 650 cfm carb would not be a bad size for the 455 I would never
use a double pumper with mechanical secondaries on a motorhome.
The vacumn secondaries are a much better choice on a heavy vehicle
like the GMC.
I doubt if I would use a double pumper on anything over about 4000 lbs
and only then with a large engine.
The carb Darren is talking about is a spread bore vacumn secondary
replacement carb for the quadrajet.
HTH
Regards
Gary Zingle
1973 GMC 26 foot =
Why dont you like the double pumper with mechanical secondaries? Not that I
know what they are, mind you.
Ron and (it is okay to tell) Julie
> desire.
> original?"
> like the GMC.
> HTH
> Regards
> Gary Zingle
> 1973 GMC 26 foot
