Most owners will never even think of this. Or even know, or care. SURPRISE=
. I do, and have. These high winds carry the oil from the main, rod, and ca=
m bearings. To lube the cam shaft lobes, cam chain, and the distributor sha=
ft bearings. Then to cool the pistons. Our oil pans are very deep. As to ke=
ep the oil in the pan. From being picked up like the water on top of the =
waves on the ocean. We have 2 different situation going on inside our pan. =
1 We have an area in our pans at the front that keep suspended oil close to=
the crank. That can help cause oil to stay in suspention in the crankshaft=
area. 2 Then our oil pans have a windage baffle on the down wind side =
wall of the oil pan. ( But not a windage tray )To keep oil from being blow=
n up the side of the pan wall. And getting too much more excess oil splash =
in suspention to cool, and lube internal moving components. Again more reas=
ons that GM didn't put in high volume oil pumps. Of give the main/rod beari=
ngs more clearance. To start with. Many years ago. In an attempt to =
get more knowledge of the dynamics going on in the oil pan/crankcase. I bu=
ilt some engines that had Lexan panels built into them. Even put lights in =
there to improve visibility.To be able to see what was happening in the eng=
ine while in operation. Promise. Even at normal idle. The amount of oil in =
suspention is huge. I have one engine that it's idle is at 2200 rpm's. At 7=
to 8000 RPM's It's crazy. But that's another story. The reasons that I did=
this. Was to get a better understanding of lubrication at low. And in the =
very high RPM ranges. Plus. Where can I find a 1/4th of a ft pound of torq=
ue,or a pony. I'm not into thinking, or assuming things. Bob Dunahugh 78 R=
oyale.
oyale.
