> >> Thought I would check this out. See how many of us there are.
> >If the majordomo is telling the truth, there should be about 6 on the
> >regular list and 1 on the digest version.
> One reason the list may be a little slow, is a large number
> of GMC owners are on the road right now.
Well, the list *is* only a few days old, but I have also received a
couple emails from GMC'ers saying they'll check out the list when they
get back home.
According to majordomo, this morning we're up to 8 subscribers plus 1 on
the digest. If you're curious, you can send an email to
majordomo with the text body "who gmcmotorhome"(omit
quotes). The majordomo will reply with an email containing a list of
subscribers.
Tech Tip - Next time you have an opportunity to slide under your GMC,
check the steel brake lines that run along the frame rails to the rear
wheels. These lines are mounted flush to the side of the frame and can
hold water and other nasty stuff between the tubing and the frame. I
found out the hard way, when I went to move mine and had no brakes. The
line had rusted through in the area behind the forward rear wheel.
Luckily, it was in the driveway when it happened and the only harm done
was dumping a half pint of brake fluid on the ground.
Patrick
Patrick Flowers
Mailto
atri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
