Help with plumber under the sink
al chernoff
737
The hoses behind the sink go to some connections in the wall. You can get to them by removing some of the rear screws that hold some of the back plates to the under sink, and the ones to the left of
the sink drawers. When I took the drawers out, I noted a set of cutoff valves to close or open to drain. If you have these, then the hose that might be leaking is only a short one from the sink to the
valve. You can get parts at any rv parts store. They can sell you a piece the lenght you need and then some connectors for each end. Hope this helps, but if you will remove some of the panels on the
back wall under the sink, you will have a good start at seeing what is there.
al
> Hi...
> Found there's water leaking under sink, Saw there's a crack on the black plastic hose. I guess I need to replace the hose but I don't know where the other end is. Hope you understand the question.
> Many Thanks in advance,
> Ted
> 1976 Palm Beach
> Louisville, Ky
You might want to look at Scott's pictures
http://members.aol.com/adohen2/page/index.htm
gene
>al
>> Hi...
>> Ted
>> 1976 Palm Beach
>> Louisville, Ky
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Scott,
When are we on the net going to meet at your place and put MY 1/100th of a
GMC together again?
How bout it guys/gals, any takers for on hand experience in putting a GMC
together again?
Anonymous in Mississippi
>Scott,
>GMC together again?
>together again?
Carefull Scott, I think your 100th might be the slide valve on the black tank.
Dave (& his "do it all" assistant, Dege), '76 Royale, Santa Barbara, CA
>Scott,
>GMC together again?
>together again?
Hi Anonymous...
Have experience in making two halfs a whole GMC. And then there's the "take
it apart so I can fix it and find out that I need to do more than I
thought" state of affairs.
How's the end of July sound?
Henry
