My coach came with a nice but not installed oak dash inlay. Since the OEM plastic one was pretty scruffy looking, I installed the oak one. Now I have
no labels on my switches. So I don't think of Main/Aux tanks, its just one tank or the other one, or more importantly front/rear tank. Whichever one
has more than 1/2 tank is the one I run on. When I get down to 1/2 tank, that's when I start looking to refuel (and I need a pee break myself
anyway).
If you haven't studied the effects of up/down hills and braking on the GMC, goto
http://bdub.net/gmcmotorhome.info/tank.html
Worst case is braking going downhill.... if you are under 3/4 tank you could easily empty the rear (main) tank into the front (Aux) tank.
We had a club member and long-time owner run out of gas coming down the hill into Watkins Glen NY. He had lots of gas, but it was all in the front
tank. He also did not have an auxiliary brake vacuum pump so he had no brakes either! The light at the bottom of the hill changed just in time for
him to roll right through.
You may want to read up on the brake vacuum pump upgrade:
http://bdub.net/gmcmotorhome.info/addens.html
Bruce Hislop
ON Canada
anyway).
Bruce Hislop
ON Canada
