So we are on the road for a spring break trip at a gas stop. I went to check the oil, and was greeted by the dreaded milkshake of coolant in the oil.
No oil in the coolant I can see. We are in Plains, TX, which is pretty desolate.
Here’s a brief history of the mechanics of the coach recently:
I had changed out the heads last year due to a burnt valve, and drove the coach on several trips since then(including one to Florida from Texas in the
middle of summer with only one issue. The coach chucked a belt on the Florida trip, which jammed the water pump briefly. I was able to stop it
immediately before it overheated. I replaced the belt with the proper sized one on the road. All seemed fine at that time so I continued with the
trip.
Before our current trip, I decided to change out the water pump and fan clutch as a precaution from the trauma from the thrown belt. All went well
with the water pump swap and the coach ran fine for about 500 miles since then. Till now, of course.
My thoughts are (assuming nothing is cracked) intake manifold gasket leaking water into the valley... But would welcome any advice from the gurus on
this site. Soonest the local auto parts store can get the intake gasket here is Wed, so thinking of buying some gasket material and cutting one out
just to get us home. Then change the oil several times and hope for the best. We have a Jeep dinghy at least... But wife and 2 kids are less than
thrilled.
PO had used grade 8 manifold bolts, which I reused on the head swap. Have since learned this is not a good idea, but had not changed them out as
everything seemed fine.
Definitely changing them now. Any advice on how to best seal up the manifold, if that is indeed the issue? Appreciate any of advice or suggestions
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
trip.
thrilled.
Howell Injection,
Fort Worth, TX
