I was driving it and when I go like 25 or more MPH this vibration on the right side, thinking it something to do with the suspension, any ideas, would help, Surrey, BC
One thing he said was it needs a wheel alignment, so would that be it? He put new tires on it was not balanced!
Hi,
A voice of "trial and experience", 200+K miles & 34 years.
This started about 40 years ago, no reason NOT to expect the same results NOW with similar conditions.
Test vehicle:
1976 Palm Beach GMC MotorHome
8.75x15.5 radials (various brands over the years)
original steel wheels w/GMC hubcaps
starting mileage ~40K
new Delco shock absorbers (on rear, replaced with KYB later))
A wonderful coach, loved everything about it except a vibration from the rear suspension!
Methods tried to fix the vibrations.
Balance using lead weights with both static & spin methods.
Result: At best, changing the speed where the vibration occurred or minimally reduced it.
At the time there were Dynamic balancers (an accessory using a tubing ring with steel balance balls inside clipped to the inside of the wheel. The balls were distributed centrifugally where needed for balance.
Result: Somewhat better over lead weights, but still a "patch" not a real FIX.
Finally, new 16" alloy wheels w/tires.
Result: The fix is in! Excellent ride with little to no vibration. Add glass beads and you have perfection.
Pretty much unknown to the public was that in 1973 MH steel wheels were sorted from the best truck inventory for the motorhome use. Obviously GM knew the rear MH suspension was subject to imbalance, I'm sure the bias tires didn't help.
Other ways to balance tires is to grind the tread??, your mileage may vary.
Balance beads (inside the tire) work very well and are a good fix.
