Helium absorption refrigeration - What??
Matt Colie
11,101
807
113
South East Michigan near DTW
> hey thanks all - I guess I'll be leaving it on!
> BTW this isn't an ammonia fridge it's a helium fridge ( not that there's anything wrong with that! Laughing )
> thanks again will report back on progress
> all the best
> Larry
Larry,
There is obviously something you don't understand about absorption cycle refrigeration.
The hydrogen and now helium are there to make the ammonia behave like it's pressure has been reduced.
This is kind of like the function of the expansion valve in a vapor compression cycle.
The rest of the system is the same as any other absorption system.
It has been in use since the mid 19th century, but the three fluid is much newer as it came along in the early 20th.
