When the Honda 250cc Elsinore series first was introduced, they were more
powerful, faster, lighter, handled better, than the European offerings
from Montessa, Ossa, CZ, Bultaco, Maico, and others. But, shortly, frame
cracking, and exhaust system breaks and cracks reared their ugly heads in
the Hondas. High frequency vibrations along with poor or no heat treatment
on the frames was blamed. Cure, strip the bike down to bare frame and
inspect all welds. Fix the broken ones, and mag check the rest, then heat
treat it and repaint. Trackmaster and Redline both marketed replacement
frames for Elsinores. Racers bought a lot of them. Lots of aftermarket
exhaust systems were introduced about the same time. Better stuff, held up
quite well for the most part. Exhaust system sounds set up vibrations that
crack and break very substantial components. No one cure for everything.
Very situational.
78 GMC ROYALE 403
James, James, James. What's this old stuff about? So. The average age of
owners of GMC's is near death. Mentally I'm 35. I use that series 40 Flow
master on my track Yenko's. There mounted directly on the headers with no
tail pipes. The sound to me is a symphony in all it's glory. And at 7 to
8000RPMs full throttle. WOW. Gear heads understand that one. As to the GMC.
I have a microphone on my rear view camera. Yes the sound level is elevated
some. Inside/up front. Again. Slightly elevated. Then the harmonics. That's
not lowed, or last long. I'm just stuck on why. After all. It did break up
a new $80 sheet metal muffler. As to a resonator at the back. ONE. I don't
have room back there due to a floor drain. Two. As to the sound at the
back. I turned the mic on the camera off. Bob Dunahugh
Sent: Friday, June 16, 2017 11:33 PM
Subject: RE:Harmonics in my exhaust system
This is my thought on the source. ( MAYBE ) The entire exhaust system was
on the 78 Royale that burned. Plus the front, and rear suspension. Then
trans, and 3:70 FD. There are 122 GMC VIN's between the two 78 Royales.
The burned one was built in Dec of 77. The Mouse House in Jan of 78. The
only item that wasn't from the burned GMC drive line is the 403. And the
only difference between the two 403's is the camshaft. The 403 from the
burned 78 had compression readings from 130 to 135 psi at 152,000 miles.
The Mouse house compression readings were 140 to 145 psi at 1884 miles.
Thus the only things different is a more aggressive towing cam. And a
little higher compression readings. Bob Dunahugh
Sent: Thursday, June 15, 2017 7:58 PM
Johnny. I don't think the tail pipe is vibrating due to the two muffler
bearings being as tight as they are. The harmonic sound seems to be coming
from the muffler area. I don't lug engines of any type. When I'm going up
long climbs. I down shift, and run the rpm's up to the 4000 rpm range with
moderate throttle. I like the water, and trans fluid pumps moving fluids
faster. That's why I get to those rpm ranges. The thing here is that I
never had this problem with this exhaust system in the burned 78 GMC.
Bob Dunahugh 78 Royale
Sent: Thursday, June 15, 2017 1:03 PM
Subject: RE: Harmonics in my exhaust system
Larry. You have an excellent point. Next. I should have said double outside
wall mufflers. The exhaust system is pure stock ( except the mufflers now )
down to the proper hangers, and GM muffler bearings for the tail pipe.
Sound out the tail pipe is up a little. What helps there is that the tail
pipe points straight out the back. As to the 403. Has about 7000 miles on
it now. Bored .030 over, towing cam, standard bearings, stock oil pump,
roller cam chain, 3 angle valve job, new plugs/wires and was balance.
Compression test at 1884 miles were 144 to 149 psi. Hope to get the EFI
with spark control on soon. A bright side is that I'm at 2100 rpms for
very short times. The 4000 rpms can get stretched out on long hills. Most
driving is in the 2800 to 3000 rpm range. Bob Dunahugh
Sent: Wednesday, June 14, 2017 9:14 PM
Subject: Harmonics in my exhaust system
The harmonics happens at about 2100 . Then stops. Then returns at about
3900 to 4100 RPMs. But not as strong. Both at moderate throttle. It's a 403
with a stock exhaust system. I thought it was the double wrapped mufflers.
So I put on two Flow master series 40 units. No change. But these are
real solid/welded mufflers. I have an idea. Any thoughts? Bob Dunahugh 78
Royale 403
