Gutted 73, some good parts
GURR
16
1
Hey all, I have some parts to sell from my 73. I'll just list them out, list isn't that extensive.
Interior
- upper bathroom cabinet (no mirrors? maybe I have them)
- lower bathroom frame
- propane tank
- water tank
- toilet
- window trim
- dining table hardware/leg
Engine/steering suspension
- mechanical fuel pump (new, only used for a few miles)
- airbags (weather rotted, one with aluminum cones, one with plastic)
- brake master and booster (worked, pretty beat)
- backup vacuum pump (looks like it's been replaced at some point)
There's probably more, but this is what I have now. I'll be posting more.
dm for photos!
Located in the greater san francisco bay area.
I would be interested in the little button switch that turns all the lights on or off at once if you have a good one with harness.
I think the random one I have doesn't have a harness and seems to have a clear button. Not 100% sure it worked when I pulled it off, but it makes a clicky sound....I'm sure that means it works perfectly...PXL_20230427_142301196.jpg
That is not an OEM switch. Since it appears to be in the bath, do you mean "all the bath lights?"
Yes, just all the bath lights. That switch was only on the early ones. We have a 74 Canyonlands.
Your switch looks much thinner then mine but also looks like it does the same job. You could check it with your volt meter on continuity. I would be interested if it works.0427230933.jpg0427230934.jpg
We have a 73 Canyonlands and are missing 3 of the sliding window latches. Also missing the ashtrays on the driver and passenger seat walls. We are in sacramento so I’d love to come see this in sfbay area
I’m looking for a steering box, steering intermediate shaft and a relay arm to get overhauled. I will be in the Bay Area mid month if you have any of these
Interior
- propane tank
- water tank
- toilet
- window trim
dm for photos!
Are you selling any of the aluminum subframe material that supports the floor and sides?
Interior
- propane tank
- water tank
- toilet
- window trim
dm for photos!
Is this a 26 or a 23? That makes a difference in the parts I might like.
Matt_C
Interior
- propane tank
- water tank
- toilet
- window trim
dm for photos!
I’m in need of a complete dinette set. You seem to have the table, how about the rest?
Talk me about the propane tank.
I did not get one when I got it and would like to have one.
I have tried three ones and two had leaks and one was too tall.
Photos please.
Robert
