guages
eric.henning
56
As part of my cross-country preparations, I am going to add at least the
following guages: Oil temp, Tranny Fluid temp, final drive temp fluid. Where
have others put the sending units for these gauages? I am not asking where to
mount the guages themselves, but the sensors. The tranny and final drive
sensors I can drill a hole in the pans, is this the way to go? The speed shop
suggested for the oil temp, teeing off the oil pressure sender.
I also plan on adding a tachometer. But that is straight forward.
Any other "must" have guages? engine vacuum? voltmeter? ammeter ( is the
stock alternator over 60 amps?)
eric henning
eric.henning
73 sequoia
Eric,
I think most people running the trans and final drive temp gauges use the
Ragusa RV(www.ragusarv.com) tranny pan and final drive cover, which have
threaded holes for these sensors.
> at least the
> temp fluid. Where
> not asking where to
> final drive
> go? The speed shop
> ammeter ( is the stock alternator over 60 amps?)
> eric henning
> eric.henning
> 73 sequoia
Did you look here under Suggested Gauges ??
http://www.california.com/~eagle/gauge.html
that should blow your mind ;>)
also might want to look at the tach/vac gauge on this page
gene
Where
where to
shop
the
>eric henning
>eric.henning
>73 sequoia
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
