Arch
By any chance do you know what is the original antenna for the GMC.
We still have our original CB-& Radio which works but the antenna is in
poor shape. What has happened is that the wire just pushes in the bottom of
antenna and there is no way to attach it tight poor contact.If it was on the
roof originally then it has been moved and attached to the side mirror. Is
there something we should know in regards to #'s that we need to know to
purchase something else to take it's place?
Marlene
----- Original Message -----
To:
Sent: Sunday, August 06, 2000 5:39 PM
Subject: GMC: GMC: Good weekend
> GMCers
> Well, good weekend. First off tried to deal with two small leaks that
> I still have if the wind blows just right. First thing I did was to
install
> a rain flair over the door. Ran into a guy in MI that had one installed
> by Jim Bounds and he said it solved all of his problems. Used a different
> one and heavily modified it because of my new porch light. It looks
> like it should work. I sure hope so dont think the reefer module can take
> much more. It seldom leaks but when it does it sure does. They say
> we may get a storm out of the South tonight-----it we do-----we will know.
> The next leak is over the stove. I have fought this one for far to long.
> I installed a new outside vent and flapper. Did not like the way the cover
> was way to open. So I designed a SS cover that goes all the way down
> to the bottom of the outside vent. That stopped a lot of my problem.
> This last trip out we got 2 inches of rain in 4 hrs. It leaked again. Took
> the whole fan assembly out of the cabinet. To my surprise there was dust
> on top of the duct and the bottom of the inside. That means the rain
> did not come in through the vent cover. Got up on the roof and crawled
> around. found a half dozen places where the caulk had cracked on top of
> the rails. Two were real near the stove. We shall see.
> Got my CB and a radio installed. I will never travel again with only the
> TV for weather reports. That little 8 inch CB antenna I reported about
> seems to work well. The weather band on my CB is as clear as it was
> in the LeSharo with a 24 inch Fire Stick. I could hear people talking on
> the CB. I live in the middle of 40 acres of timber so I have to wait till
> late evening to get much CB traffic. SWR is 1.3 with no adjustment
> to the antenna. The guy I bought it from said to bring it by when I got
> it in and he would adjust the rings for me.
> I took my old radio to Radio Shack and found a new one that fits real
> well. It is an AM/FM Cassette and the shafts all line up. The front
> cover even fits----well I did have to get some washer to make it work.
> BTW if anybody wants a GMC, AM/FM stereo with CB I have one. It
> is huge. Must be 25 lbs at least. Two different boxes. Whole lot of room
> in dash without that thing in there. I also found the meaning of the
switch
> that I have mentioned that was hot but seemed to do nothing. It was
> hooked to a FM signal amplifier. One more mystery solved. While I
> was at Radio Shack I also found a dual cone full range 3 1/2 speaker
> that is a twin for the ones in our ladies. 20 watts with a catalog # of
> 40-1325A. I dont know how good it is because I did not find anything
> for the rear speakers. Any body got a good recommendation? I would
> like good speakers for back there. I know what the cross over Manual
> has but I would like to hear ideas from here.
> That is what I did this weekend.
> Take Care
> Arch 76 GB IL
> To unsubscribe, e-mail: gmcmotorhome-unsubscribe
> For additional commands, e-mail: gmcmotorhome-help
Marlene
To:
> GMCers
install
switch
> Take Care
> Arch 76 GB IL
