We weighed every coach at Casa de Fruita, and checked ride height as well.
Armand Minnie did a spread sheet on them. That might still be around. As I
remember, that info was hard to make any definitive conclusions from. But
the weight per axle, and side to side differences were an eye opener. Ride
heights on perhaps 25 coaches were all incorrect except for 2 coaches.
Funny, the drivers all said their coaches drove fine.
Salem, Oregon
On Wed, Jul 24, 2019, 6:41 AM Jim Kanomata via Gmclist <
> John,
> Your explanation should answer the question .
> Too many variables.
> Just the different models like the Royal by Coachman can be big .
> On Wed, Jul 24, 2019 at 5:36 AM John Wright via Gmclist <
> > Ken,
> > I would suggest that there is no OFFICIAL WEIGHT of each coach model,
> > there are too many variables.
> > How much fuel in tanks.
> > How much water in tank.
> > How much waste water in tanks.
> > Aluminum wheels vs steel wheels
> > Tire weights.
> > How much spare parts are stored, so have more that others.
> > How much food and supplies.
> > Anything that is in the coach or storage pod that did not come with the
> > coach.
> > The list goes on with options added from the factory.
> > The real official weight is the one you get when you weigh your coach.
> > That is why so many people are surprised when they have their coaches
> > weighed at the GMCMI conventions. I know that why you like your 23’
> coach.
> > The coaches that we have had over the years have weighted differently
> > depending on the time it was weighted. By time I mean was it going on a
> > trip, emptied out after returning, what it was going to be used for, etc.
> > The 77 Eleganza II was a frame up restoration and some cabinetry had been
> > replace and newer materials along with the newer windows that you used to
> > sell and they were much light than the stock windows. When empty it
> alway
> > weighted under the gross weight listed on the TZE plate. When loaded for
> > traveling and we used to do Florida and AZ for 4 months it was 1000# over
> > name plate and that is not uncommon.
> > The 78 Buskirk Stretch is a much heavier coach as it has a 3.5 foot
> > addition, heavier frame rails, 3 fuel tanks, custom bath and shower
> > modules, new furniture, custom solid maple cabinets thru out. It weighs
> > right at 12500# empty and close to 14600# ready for battle. The coach
> > suspension is much more robust than a stock coach. Heavy duty front
> lower
> > “A” arms that have billet hexes welded in, reinforced with 3 1/16” plate
> > welded in, larger torsion bars along with a larger sway bar in the front.
> > The rear is a copy of the Leigh Harrison 4 bag suspension that has been
> > beefed up with larger steel plate supports and modified swing arms, and
> air
> > bags that are the largest used on a 4 bag coach setup.
> > So again is there an actual listing of coach weights, it weighs what it
> > weighs when you have it weighed.
> > JR Wright
> > GMC Great Laker MHC
> > GMC Eastern States Charter Member
> > GMCGL Tech Editor
> > GMCMI
> > 78 GMC Buskirk 30’ Stretch
> > 1975 GMC Avion (Under Reconstruction)
> > Michigan
> > > On Jul 24, 2019, at 7:03 AM, Ken Henderson via Gmclist <
> > > I just got a question from a GMCer to which I can't find an answer:
> What
> > > is the "official" curb weight of a GMC? The maximum gross weight is
> > > documented several places, but I've been unable to find anywhere what
> the
> > > "curb weight" should be. I certainly recognize that each configuration
> > > will be slightly different, but it seems there would be established
> > numbers
> > > for each SOMEWHERE!
> > > Ken H.
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
http://www.appliedgmc.com
> 1-800-752-7502
