GMCer broke down in Birmingham
kerry pinkerton
2,443
Got a black list call from a GMCer from Chicago whose name is Jim Croc. A bit hard to understand but as best as I can tell, they started having brake
problems and he hears a hissing sound down by his feet. I told him two hours ago to lift the hood and check to make sure the vacuum hose is plugged
into the booster. He also said the motor was running rough. If so, I told him to start the coach, check the reading on his vacuum gauge, and see if
he can determine where the hissing sound is coming from. He called back an hour later and had not yet done that. I told him to go do that and call me
back. It's been an hour and a half and is now dark.
He told me he was "IN" Birmingham and I asked him if he had gone through Birmingham yet and he did not know...nor did he know where he was other than
off I65 in a parking lot. There are places off I65 near Bham where you don't want to be.
On the second call he told me that Jeff Sirum had done some work but didn't elaborate on what. He also said he had needed to add brake fluid to his
relatively new master cylinder so I told him to check the fluid. That's been over an hour ago.
Given what he's said, I suspect a big vacuum leak, possibly in the booster. He does not know if he has an auxiliary vacuum pump or vacuum tank.
Other options are an empty MC and that means a pretty significant leak somewhere down the line.
He did mention he is towing a Tracker so he at least has a way to get somewhere safe. I'm concerned but can't help if he doesn't talk to me. He's at
least two hours from me and I have commitments tomorrow and won't be able to help.
If someone knows Jim and wants to call him, give me a call at two56-six79-fourfour88 and I'll give you his phone number.
Kerry Pinkerton - North Alabama
77 Eleganza II, 403CI, Manny Brakes, 1 ton, tranny, lots of aluminum goodies.
http://www.bdub.net/pinkerton/
'03 Fleetwood Discovery 39L
Jeremy Knezek called me and offered to help but we needed a location. Jim Croc finally called and said the hissing was coming from the booster. I
told him we needed to know where he was. Jeremy was going to drive over and see things first hand. Jim said he didn't know but there was an Exotic
Wings across the street and he was at a Shell station. I asked if he could walk to the Shell station and ask the street number and exit off I65. He
said he would and call me back. I was thinking while waiting for him to call back (8:45) and googled "Exotic Wings" and got the map, found the Shell
station across the street and called. I asked the guy who answered if there was an older fellow in an older motorhome in his parking lot. He said
yes and I got his address and exit. I then asked if the guy had asked him for their address. He said yes but he had gone back to the motorhome.
I've had no calls from Jim and my calls to him go to VM so I don't know if his phone is dead or if he's gone to bed.
In the meantime, Jeremy and I have been talking. Jeremy offered to drive 25 minutes to do a face to face but not unless he knew the guy was expecting
him. I don't blame him. Jeremy has to be away tomorrow and I asked if he would leave a message for Mark Creel who is the only guy in Bham who MIGHT
have a booster and know how to install it.
Jeremy called back and said that his call to Jim also went to VM but that to his surprise Mark Creel answered his shop phone at 9:30 on a Saturday
night. Mark said he had some boosters and would call Jim in the morning and make arrangements to get him going. Hopefully all this will work out and
Jim can get back on the road to Chicago. Apparently, he has had 6 back surgeries, is out of medication, and has a doctors appointment he needs to get
back for.
Kerry,
Sounds like you're making some progress if Creel's going to contact him.
Thanks for the Good Samaritan / Black Lister help for another GMCer!
On Sat, May 27, 2017 at 10:57 PM, Kerry Pinkerton
> I65. He
> and
> get
> back for.
> goodies.
Hopefully he can get fixed and back on the road. Kudo's for your efforts in helping him out, The black list is an awesome resource.
JD Lisenby- USAF Ret
1978 Royale-455
Electromotive Tec2 FI & ignition
Navarre, FL
Called at 9am. Went to VM and left a message that Mark Creel will call his this morning. Jeremy asked Mark to go to his location if all else fails.
Its now almost 10 and no word.
Note to others. If you are working with someone on a problem, STAY IN TOUCH. This is REALLY frustrating.
Note to self. Making long trips through unfamiliar territory in a 40 year old vehicle that you do not know much about may not be the best idea on a
three day weekend.
I found trying to rescue a gmc once that a sunday is also not the best day, but sometimes you have no choice.
Good job sticking with this and hopefully he gets going ok. I can't image what it was like before cell phones and internet, trying to criss cross the
country, much less in a gmc. Probably fewer places to worry anout your safetly in breaking down and more people able and willing to help in person
back before cell phones. i am guessing this guy is not too technically savvy and making a cell call is a chore. but that is still great he is out
traveling.
Hope to hear a good end to the tale.
Jon Roche
75 palm beach
St. Cloud, MN
He called me about 11:30. He had his ringer turned off and did not know why he had not called me back last night with his location. I talked him
through turning on his ringer and had him hang up. Then I called him back and VERIFIED that he heard the ringer. He said he did.
I recapped that Mark Creel was going to call him today and work with him to get back on the road and probably had already tried to call him. He was
to call Mark's business phone as soon as I hung up and leave a message for Mark if Mark did not answer and to wait for Mark to contact him. I also
told him that Jeremy would call him either later tonight or tomorrow.
I'm glad he is OK and hope this works out soon.
Great follow thru Kerry! Thanks for caring!
Mike/The Corvair a holic
Sent from my iPhone
Kerry, you and Jeremy have gone beyond what most would do. Thanks for
persisting. Sounds like he needs help on several fronts.
Sandra
Sent from my iPhone
> On May 28, 2017, at 12:49 PM, Kerry Pinkerton
goodies.
My standard for fixing transmitters when the manager or program director is the only person onsite, "If you will be my eyes and my ears and my hands I
can fix this." They must assume nothing, report neverything, and take no undirected action.
==johnny
Braselton, Ga.
Jim called me last night some time after 11 p.m. I gave him Mark's number and told him to call Mark in the morning. I spoke with him this afternoon.
He had not heard from Mark but didn't know how to check his voice mail or previous calls. I did call Mark's shop again but it went to voicemail. I
will be back in Birmingham late tonight but will try to check in with him and Mark tomorrow. It is just very hard to help him right now because he
doesn't communicate easily.
Thanks,
Jeremy Knezek
1976 Glenbrook
Birmingham, AL
I called Jim about 5:30 and he'd not heard from Mark. I told him that I expected Mark had tried to call this morning when his phone was disabled and
we'd just have to wait. I called Jeremy to update him and found out that Jim had called him last night. In my two long conversations with Jim today,
he did not tell me he had spoken to Jeremy.....
Jim did say that he had checked his master cylinder and added fluid but he did not know if it was dry or not because he can't see into it. I had him
press the brake pedal with the motor OFF and he has a high firm pedal and the hiss only happens when the brake is pushed. I told Jim to keep his
phone charged, ringer on, and with him at all times and we would not be able to help him if we could not get in contact with him. I'm sure he thinks
I'm a redneck jerk.
Jeremy just called to say that he had just heard from Mark. Mark had tried to call a few times this morning and the phone went straight to VM and he
moved on to other things. Shortly after I spoke with Jim this evening Mark contacted him and they spoke for about 1/2 hour. Mark and Jim are going
to try and get the coach to Mark's shop in Bessemer in the morning and Mark will fix it. He, and I, believe there are multiple problems. Obviously
the booster is an issue but losing brake fluid is a problem. The coach was worked on at two of the FL shops but it's unclear to me who did what,
when, or at all.
At this point, Jim is in contact with a professional mechanic and I'm going to back out and let them handle it. Hopefully Mark can fix it quickly and
Jim can get back in time for his Friday doctors appointment. I guess if all else fails, he can leave his coach and drive home in his toad.
Congratulations, and thanks, Kerry.
On Sun, May 28, 2017 at 8:41 PM, Kerry Pinkerton
> quickly and
Just a quick update. Mark was out looking for Jim Croc this a.m. Unfortunately due to Mr. Crock still not knowing where he was, he sent Mark 20 miles
in the wrong direction. Mark called me for help and I gave him the locatin Kerr had discovered Saturday night. Hopefully he is still there.
Thanks,
Jeremy Knezek
1976 Glenbrook
Birmingham, AL
Amen Kerry:
The frustration level is WAY over the top on this one. But thank you guys for hanging in there and assisting a fellow GMCer!
You guys and your attitudes are what make this group so very unique and enjoyable!
Happy Memorial Day
Sent from my iPhone
> Good lord, I need a drink. Hopefully Mark will hang with it.
