I don't think you'd ever live long enough to wear one of these CV joints out
if you never had a boot failure. If you keep the grease in and the dirt out,
my guess is they'd last forever.
I've had them fail on an Eldo (same exact joint) and you described the
symptoms exactly. The good news is they won't strand you.
Travis
- -----Original Message-----
To: gmcmotorhome
Date: Friday, April 23, 1999 10:17 PM
Subject: Re: GMC: GMCC V JOINTS
>Gene
>When I redid mine they were in perfect shape. Still shiny with no wear
>signs at all. Mine had 128,000 miles on them. I cant speak to loosing
>one on the GMC but I recently lost on my front wheel drive van. It first
>started to feel like I had a loose wheel when I made a turn. The steering
>wheel would shimmy. Then as it got worse it would knock or click when
>I went around a turn. Hope this helps.
>Take Care
>Arch 76 GB IL
>In a message dated 4/23/99 9:53:43 PM Central Daylight Time, W4BJC
>writes:
>> What should I look for to see if the joint should be replaced,wear and
>etc.It
>> looks like
>> the might be some groving where the balls bearing move up and down .
>> Also what happens when one of these things fails.What kind of symptoms
>> preclude
>> failure.
>> Gene
Travis
To: gmcmotorhome
>Gene
>Take Care
>Arch 76 GB IL
>writes:
>etc.It
>> looks like
>> preclude
>> failure.
>> Gene
