GMC steering
terry doukas
99
Got my brakes on the front and bled, new shoes and I wiggled the steering
linkage after I put on the front tires and the "idler" arm or pitman arm,
which ever it is called is terrible, What is the part number and where do I
get it?
Thanks everyone,
>From the Desk of:
Terry Doukas
http://tadoukas.homepage.com
tadoukas
1975 Glenbrook
Terry,
I think there are 3 arms all with different names. There is the pitman arm
which is attached to the steering gear box on one end and a tie rod on the
other end. The other end of this tie rod connects to the relay arm. The
relay arm has a bolt in the middle which mounts to the frame cross member.
The other end is connected to the main tie rod which connects both front
wheels together. It relays steering commands from the gear box to the main
tie rod. There is an idler arm on the passenger side that is hooked on one
end to the main tie rod and the other end is connected to the same frame
cross member mentioned above. That description ought to make it at least as
clear as mud. I hope it helps.
Bob McLaughlin
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of Terry Doukas
Sent: Saturday, July 29, 2000 3:43 PM
To: gmcmotorhome
Subject: GMC: GMC steering
get it?
Thanks everyone,
>From the Desk of:
Terry Doukas
tadoukas
1975 Glenbrook
I can't get the GMCmart page to work, but Jim Bounds has all three steering
arms listed in this month's GMC Motorhome Marketplace.
Idler Arm (new) $125
Relay Lever (new) $200
Drag Link (new) $100
877-275-4462
hth
bdub
>get it?
>Thanks everyone,
> >From the Desk of:
>Terry Doukas
>tadoukas
>1975 Glenbrook
Thoma also rebuilds them and I think with an grease fitting ? if it is the
same arm.
gene
>get it?
>Thanks everyone,
> >From the Desk of:
>Terry Doukas
>tadoukas
>1975 Glenbrook
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
It is the relay arm that is bad and it is not the bushing in the middle. The
tie-rod type end has lots of slop. Took it out for a 30 mile spin tonight
and it jump pretty good in some bad ruts.
>From the Desk of:
Terry Doukas
tadoukas
To:
Sent: Saturday, July 29, 2000 6:31 PM
Subject: RE: GMC: GMC steering
> Terry,
arm
main
one
as
> Bob McLaughlin
> From: owner-gmcmotorhome
> To: gmcmotorhome
I
> get it?
> Thanks everyone,
> >From the Desk of:
> Terry Doukas
> tadoukas
> 1975 Glenbrook
Terry,
You should be able to get a new tie rod end at a reasonable price and it
should be easy to change. It might be best to call Cinnabar. I don't
recall anyone posting part numbers for these. Do you have the phone number?
Bob McLaughlin
Sent: Saturday, July 29, 2000 11:09 PM
To: gmcmotorhome
Subject: Re: GMC: GMC steering
>From the Desk of:
Terry Doukas
tadoukas
To:
> Terry,
arm
main
one
as
> Bob McLaughlin
> To: gmcmotorhome
I
> get it?
> Thanks everyone,
> >From the Desk of:
> Terry Doukas
> tadoukas
> 1975 Glenbrook
The steering arm is not available new. You can get yours rebushed &
rebuilt at Buskirks and it will be like new. They might even have units
available for exchange. Call Max Monday morning 800-715-1133 an he can
help you out.
> get it?
> Thanks everyone,
> >From the Desk of:
> Terry Doukas
> tadoukas
> 1975 Glenbrook
J.R. Wright
GMC GreatLakers
Michigan
