GMC : Onan
donald w. miller
188
> Richard,
> Thanks for the kind words and vote of confidence, but it was not I. I
did
> discuss finding a replacement bridge rectifier, but I must admit I know
very
> little (yet) about Onan control boards. (Mine still works, so haven't
gone
> there. Yet.)
snip
> Rick Staples
> '75 Eleganza
> Louisville, CO
Rick and others,
I meant to comment in the bridge rectifier discussion the other day but
family events intervened.
Bridge rectifiers often burn out because people start and stop gensets while
there is a heavy load on the output.
This stresses the bridge rectifier. A way to save the rectifier is add a
fuse in series with the rectifier circuit.
I did this with our boat genset. When some one forgets to turn off breakers
first, it will save the rectifier.
I am not sure what value fuse the Onan would need, maybe one of our experts
will know the maximum working field current ?
Also some recent posts advised never run an Onan without a load present.
Does the operators manual say this ?
Automotive alternators need a load present or you can blow output diodes
because voltage soars to a high value without a load present.
It's an unjust world, probably politically incorrect to even mention, but
alternators are NOT created equal.
The Onan design is different and appears immune from needing a load to limit
it's output voltage.
So, is this a "myth" or does someone have an explanation for the advice ?
Don Miller
75 Glennbrook project
Shenandoah Valley of Virginia
My GMC service manual says not to run without
a load...or was that without a battery???? I'm
too busy to check now.
Rob Teed 74 Painted Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of Donald W.
> Miller
> Sent: Wednesday, May 12, 1999 4:07 PM
> To: gmcmotorhome
> Subject: Re: GMC: GMC : Onan
> > Richard,
> not I. I
> did
> very
> gone
> > there. Yet.)
> snip
> > Rick Staples
> > '75 Eleganza
> > Louisville, CO
> Rick and others,
> gensets while
> off breakers
> our experts
> load to limit
> Don Miller
