>6kw Ownan generator quits running when I start moving. My oil level is good
>and my fuel pump is working. Any ideas out there?
It sounds like you might have a wire that shorts when the coach is
moving. I would suggest that you disconnect the plug going to the
inside remote panel. The plug is at the lower right rear of the Onan
compartment. Once you have this unplugged, start the Onan from the
switch on the side of the Onan. Then get in your GMC with the Onan
running and try to drive around and see if it keeps running.
If it doens't go out with the remote panel disconnected, you probably
have a short in one of the wires that go to the remote.
You can check these wires by disconnecting them from the remote panel
and then get a long wire and an ohmmeter. Check the continuity of
each wire from the panel end to the compartment plug end. Also with
them disconnected and with the plug unplugged check each one to
ground. If one shows a ground, then it is shorted and the best way
to fix it is to just run another wire.
We did this to Walter Drew's coach several months ago. First we
tried to find the short but couldn't. The easiest thing to do was to
run another wire.
Emery Stora
77 Kingsley
Santa Fe, NM
run another wire.
Emery Stora
77 Kingsley
Santa Fe, NM
