GMC Motorhome Digest V2 #381
scott shean
108
Duane, I agree that if the Hayden 2797 worked for me as it does for you, it
would be my first choice. The 2797 NEVER stopped "roaring", and the 2747
"roared" continuously until I reached 45 MPH. This happened with an empty
coach. It also happened with a 20' boat in tow, so I think my cooling
system is OK.
All I want is the same fan clutch as my original. It hardly ever came on.
Scott (still testing fan clutches) Shean
78 Royale
Baton Rouge, LA
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of duane m simmons
> Sent: Friday, April 16, 1999 12:48 PM
> To: gmcmotorhome
> Subject: Re: GMC: GMC Motorhome Digest V2 #381
> To Those Concerned
> The Fan Clutch is an important element for cooling our coaches. You need
> the best you can get & a step back to a '70 design (hayden #2705) is
> certainly a step in the wrong direction....they will not do the job for
> our coach when heat is needed to be removed from the radiator (marginal
> at best). YES THEY ARE QUITE & THAT'S WHAT TELLS ME THE ARE NOT DOING
> THE JOB .To me it is like removal of the fan altogether since it will
> not come on at proper time/temperature. Most over heating conditions can
> be attributed to the fan clutch not functioning properly or wrong fan
> clutch. I prefer the Hayden #2797 (403 /455) & do not tow a car. Only
> hear the Roar at morning startup & after I top the grade when the engine
> RPM is reduced. That is the way they should work....IMHO.
> The 2747 is indeed a step in the correct direction from the #2705, but
> why stop there....Heavy Duty. Go for the best #2797 Severe Duty & only
> hear the Roar when needed to keep cool...assuming a good functional Unit.
> Sincerely
> Duane Simmons
> Sunny Southern California
> ___________________________________________________________________
> You don't need to buy Internet access to use free Internet e-mail.
> Get completely free e-mail from Juno at http://www.juno.com/getjuno.html
> or call Juno at (800) 654-JUNO [654-5866]
Duane, What did you do about those water pump studs being too short or did
you not worry about picking up all the threads of the nut. Did you use the
supplied lock nuts? Do you use locktight?
Regards, Phil Swanson
> To Those Concerned
> Sincerely
> Duane Simmons
