> Les & Dee
> I have been away for a few days & just got back !!! When you jumper Pin 7
> to Pin 1 you are simulating the Start Switch which doe the same thing
> (grounds Pin 7) except it is connected to ground thru K2 (normal closed)
> contact. Sound like your K2 relay (or board wiring) is faulty. If you
> jumper pin 3 to pin 1 & the starter engaged, then Switch is faulty. If
> not, then K2 contact (or board wiring) is faulty. Bad news if K2 relay
> is faulty since the are no longer being manufactured. If you can not
> find one on the self somewhere, then a substitute must be found. Pin
> out/packing shape is the problem & limits your selections. I have
> repaired many GMC OEM ONAN Control Boards but have not found a source for
> a pin out replacement K2 relay. Therefore, I use a smaller size relay &
> adapt it to the control Board. This is not for the novice GMC Owner.
> Much damage can be done if not installed properly. If you need help, I
> can repair almost any GMC OEM Onan Control Board at a cost effective
> price. Call or contact me.
Duane
Thanks so much for your willingness to help. Actually, what it
turned out to be was a broken solder line on the back of the circuit
board. I, Des, can't tell you from where to where because Les fixed
it, but I think it was from the fuse to one of the terminals. I know
instead of trying to run a new solder line a friend (who does a lot of
electronic work) had Les solder a wire from one end of the break to
the other end of the break. Our generator works like a charm now.
Thanks again,
Les & Des
Living Praise Ministries
mailto:lpraise
Visit us at: http://www.livingpraise.org
> Les & Dee
Duane
Thanks again,
Les & Des
mailto:lpraise
