GMC Motorhome Digest V1 #179
robert teed
170
>-----Original Message-----
>From: owner-gmcmotorhome
>[mailto:owner-gmcmotorhome]On Behalf Of Henderson
>Sent: Friday, May 29, 1998 11:52 PM
>To: gmcmotorhome
>Subject: Re: GMC: GMC Motorhome Digest V1 #179
>>.... a friend of ours that work for a car dealership says that really
>>fine steel-wool will remove haze on glass. Even though our windshield
>>has haze around the edges, we have not tried this.
>>The haze on the glass is between the laminates. It can sometimes be
>>removed by using two household irons one on each side. Haven't tried it
>yet, got
>>this information from my brother who claims to have done it before. He
>>works for General Motors. Irons on low heat will relaminate the glass to
>>the strip of plastic between the glass.
>Folks:
>Has anyone on this net tried either of the above methods to remove this
>haze?
>It is my understanding that the problem is caused by UV
>deterioration of the
>plastic laminate between the glass, a process similar to the oxidation that
>turns white plastic headliners yellow over time.
>Haze is fortuantely not such an issue with newer windows which have
>laminates containing relatively effective UV inhibitors, but in the
>1970's...well, plastics were still being perfected and heat & light
>eventually hazes those laminates.
>However, it would be a real pleasure to find a method to remove this
>haze.... other than the expensive one of replacing entire windows!
>Anneke - Houston
I havent tried this fix yet. But I will try it when I get the coach
home to work on it. I think I will try using two hairdryers first
as I think the irons may not work good because of the curvature of
the glass. However, I think its worth a try and I dont think the
heat will harm anything.
Rob
yet, got
Folks:
haze?
It is my understanding that the problem is caused by UV deterioration of the
Anneke - Houston
Haze is between the oanes of glass and is caused by separating at the edges.
You cannot remove it wiht steel wool, and I have not tried the iron trick
myself yet. Soon!
>yet, got
>Folks:
>haze?
>Anneke - Houston
