GMC Fiberglass repair
emerystora
14,608
2
1
>> My 75 Glenbrook has a couple of compression fractures on the back corners where PO backed into a sign, surface is cracked thru gel coat but no
>> hole is all the way thru but fibre is showing. On the roof are spots where surface is worn off any hints on where to get info on how to do repairs,
>> will basic auto kits from Home Depot or auto parts store work or do we need something special due to age. Primarily concerned with sealing areas up
>> to prevent more damage.
About 10 years ago I wrote an article for the GMC Motorhomes International newsletter that might some help to you.
As others have pointed out don’t use a polyester resis (Bondo) to repair it as it will not hold long term.
The article is too big to be posted here.It is in Issue 96, Summer 2006. You can get the article online at GMCMI.com http://gmcmi.com/ or, if you send me your email address I will send you the PDF file.
Emery Stora
77 Kingsley
Frederick, CO
Emery, I would like the PDF file please.
> no
> repairs,
> areas up
> As others have pointed out don't use a polyester resis (Bondo) to repair it as it will not hold long term.
> The article is too big to be posted here.It is in Issue 96, Summer 2006. You can get the article online at GMCMI.com or, if you send me your
> Emery Stora
> 77 Kingsley
> Frederick, CO
C. Boyd
76 Crestmont
East Tennessee
