Tom,
Obviously, a good resilient rubber seal is essential. Not so obvious is
the effect of the striker which the latch engages. It's not obvious to the
casual observer, but the OEM striker is a 3-part device: 1. The base
plate with a stud welded into it. 2. The ~5/8" diameter "pin" around the
stud which the latch engages. 3. Between the stud and the pin is hidden a
rubber isolator.
That rubber has deteriorated over the past 40+ years, allowing the "pin"
(really a small cylinder) to move inboard when the latch strikes it during
door closing. Then, after the latch is engaged, the "pin" moves back
outboard, relieving some of the pressure on the door seal. Adjusting the
striker for tighter closing cannot eliminate that "loosening movement".
The solution to that problem, as shown to me by Bill Bramlett several years
ago, is to make the striker a 1-piece device by replacing the small
diameter stud with a solid one the diameter of the "pin". With Bill's
striker in place, the latch engages and holds the door in the single
position to which it's adjusted. Wonderful improvement! (Note: Bill gave
me one to install at a GMCMI convention. At the next year's convention, he
found that I STILL had not installed it, so HE installed it then and
there. I was astounded at the improvement! And embarrassed by my
negligence.)
Applied GMC should have the solid strikers -- 'tho' they were recently
having trouble getting them produced. JimK may chime in here with the
current status.
On Wed, Feb 24, 2021 at 6:38 PM tom geiger via Gmclist <
> Thanks Ken, looks like this is a good method. Been needing to do this on
> the bottom of my door. The top of the door seems to be flush to the
> opening. Is there other things to do to assure everything seals up well?
> Like maybe a new rubber seal set for the door?
> Thanks,
> Tom
> Tom Geiger
> 76 Eleganza II
> KCMO
