GenSet Help? Please!
jim bounds1
2,066
Sounds like you are on the right track. I would wait for the manual and
confirm the wiring before leaving it there.
Does the system seem to work properly, does the geny start with the
battery then feed ignition from the internal alternator? #11 should
have B+ when the generator during start and run.
Good job, or maybe good guess!
Let me know if I can help.
Jim Bounds www.gmccoop.com
> On my '78 Kingsley, a previous owner has had tapped the wires going to the 6KW
> generator vitals and wired in a switch at the front of the for turning it on
> and off (starting and stopping). The remote switch (inside) would not operate
> the starter.
> I took the circuit board off and found two of the traces burned through. I
> repaired those and hooked the board up again. I could then turn on the fuel
> pump from the switch on the board and also from the switch inside (tells me
> nothing is wrong with the wiring between the generator and the remote switch).
> I then found the wire going to the starter solenoid had been cut and wired
> into the switch that had been added to the front of the generator. My dilema
> is finding where that wire was connected before it was cut. I found a
> connector on the board that had no wire going to it. No. 11, second one from
> the lower right. I found that it produced 12V when the switch was pressed. so
> I tried (ttemporarilly) hooking the wire to the solenoid to it. The switches,
> both on the board and at the remote position, would then operate the starter.
> THE QUESTION: Have I discovered the correct connection for the solenoid wire?
> If so, I'll hook it up permanently and enjoy starting the generator from
> inside the coach.
> Meanwhile, I've ordered the Maintenance Manual(s) from Cinnabar. $138.00.
> Ouch!
> The manuals are supposed to have the Onan wiring diagrams.
> Thanks for any help.
> Glenn
> Also, appreciated learning about the by-pass oil filter, new part number, and
> the Onanrv web site. Thanks to all. It's helped a lot. No substitute
> filters for me.
