Generator fuel system question
mark grady
460
Knowing that the entire think tank is assembled in NC this weekend, I hope
you've got internet access. :-)
My Onan 6K genset has been acting weird lately, and I found the problem this
morning -- the fuel pump is shot.
I've got it off, and will start with my local Onan regional center, but I
know parts there are very expen$ive.
Does anyone have a recommendation for these parts:
1). Fuel line from aux tank to the 90 degree elbow.
2). Fuel line from the 90 to the fuel shut off solenoid.
3). Fuel line from the fuel pump to the carb.
I know of course, that I can get most of these parts from NAPA, but I'm
concerned that the "generic" nature of their fuel hose may not be suited to
the gen set compartment operating temps, location, etc.
Does anyone know of a 'premium' fuel hose they'd recommend?
Further, item 3 would seem to be an Onan only part (swivel 1/8 flare fitting
end).
Anyone got a number? If not, I'll get it from Onan.
This fuel line on my coach was still original, and had a spot on it almost
completely rubbed thru. I'd never seen it before, despite all the physical
inspection I've given this gen set.
Check yours today !
Mark
Hello
Are you certain the problem is a dead fuel pump? Just on a long
shot, your gas tanks weren't low were they ??
Mike Beaton
Mark: Here is suggestion about your fuel pump. It works on the magnetic
principle. Try disassembly and cleaning. The metal plunger may be hung-up
with some dirt. Give it a try--you have nothing to lose
Bob
>end).
>Check yours today !
>Mark
