Generator Battery Draining Down
samuel pickens
101
Tom, only one thought. Someone prior may have spurred in from the main
batteries without going through the switching. All I got. Regards, Sam
Pickens picksam
Tom: Another thought: How old is your battery? Maybe your battery is
only accepting a top charge. Will all your electrical components off you
can install an ampmeter which is incorporated in most volt/omhmeters.
Install it in series with your battery positive lead and if you note an amp
draw start removing fuses until it reads zero. That will be the culprit
that is causing your drainage.
Bob
>Pickens picksam
