Rob,
You indicated a preference for mechanical "wet" gauges due to their superior accuracy. I have to agree on accuracy, but they are not necessarily the best choice for continuous automotive use.
The tubing required to connect a mechanical pressure gauge introduces several failure points. I've seen my fair share of broken/leaking tubes/hoses/gauges over the years. Failures due to chafing, flex fatigue, loose ferrule nuts, présure pulsations, yetc. Some of the leaks went un-noticed long enough to cause damage. For this reason, I prefer quality electronic gauges where feasible.
Les Burt
Montreal
'75 Eleganza 26'
> Rick,
> IIRC the failures were because a long nipple used below the "t" to connect to the engine block. Plus the nipple came from China and
> the wall thickness was minimal.
> Unfortunately the McMaster Carr drawing of the run tee does not show the wall thickness.
https://www.mcmaster.com/#50785k222/=19lbwcd
> I too purchased high pressure SS fittings from McMaster Carr for The Blue Streak to connect a separate oil pressure sender.
> Regards,
> Rob M.
> The Pedantic Mechanic
> Sydney, Australia
> AUS '75 Avion - The Blue Streak TZE365V100428
> USA '75 Avion - Double Trouble TZE365V100426
> USA '77 Kingsley - TZE 267V100808
> -----Original Message-----
> From: Gmclist [mailto:gmclist-bounces] On Behalf Of Richard Denney
> Sent: Friday, September 29, 2017 9:36 AM
> To: gmclist
> Subject: Re: [GMCnet] Gauges
> I seems to recall issues of fatigue failures caused by heavy senders
> threaded into brass tee fittings in a high-vibration environment.
> Considering the consequences of such, I built my tee using high-pressure
> steel fittings, which are forged and strong. They are also available at
> McMaster-Carr.
> I have one connection to a tube compression fitting that goes to my
> mechanical gauge, and the other for a cutoff switch for the electric fuel
> pump. I wouldn't be afraid to stack another tee for an idiot light sender,
> but it would be just as easy to wire the warning light to the fuel pump
> wire using a relay to reverse the voltage.
> Rick "who has an Equus digital gauge but has never installed it" Denney
