furnace
johnny
8,287
9
3
I forget who asked me - what happens when you pass 70 - but I finally got a look at the 'book' for the new Suburban furnace fitted to my coach. It's
either an NT 24SP, NT 30SP or NT 34SP, the book covers all of these. I suspect it's an NT-30SP. At any rate, by measurement it's 12 1/2" wide 12
1.2" tall and 23 1/2" deep. Even on cold nights around here it will run you out of the coach in short order.
--johnny
Braselton, Ga.
Johnny, was it installed from inside the coach, or by cutting a hole in
the outside wall, and installing it thru the hole?
ron C
On Sat, 29 Sep 2018 10:50:29 -0600 Johnny Bridges via Gmclist
> coach. It's
> 1/2" wide 12
> --johnny
> Braselton, Ga.
Installed from the inside. Cut the bottom of the cabinet opening a bit - not as low as the door bottom - and it will slide in and when needed out. I
>think< mine's an NT 30SP, but the book also covers a 24 and a 34. Dimensions of the 30 - 12 1/2 W 12 1/2 H 27 1/2 deep.
--johny
Braselton, Ga.
The Suburban 24’s and the 30’s are identical externally. I slid the guts of
a 30 into the installed case of a 24. I had bought a scratch-n-dent and the
new case was pretty mangled. Old case was a perfect fit. I suspect the only
difference is the number of holes in the burner—everything else appeared to
be identical.
I made a 12” square opening in a cabinet to provide access, and then
reinstalled the cutout so that it can be removed in the future.
The only issue I had was the extra-length intake-exhaust ports to handle
the thickness of the coach wall.
My furnace is NOT at the original location, but I wasn’t the one who
relocated it.
Rick “replaced this year after being cold at Bean Station” Denney
On Sun, Sep 30, 2018 at 10:22 AM Johnny Bridges via Gmclist <
> --johny
> Braselton, Ga.
Rick Denney
73 x-Glacier 230 "Jaws"
