My 73 GMC has an electric fuel pump installed by the previous owner.The
fuel pump is a Carter and is located near tanks under coach. A can type
filter was installed near the discharge of the pump. Rubber hoses are
used from the two tanks to the pump and filter and then a steel pipe to
the engine. I think there is a short section of rubber hose at engine
connection. The system seems to work fine but its a noisy little bugger
and I am concerned about safety. I have a manual switch for it, but no
safety feature to cut off pump if engine isn't running. I have seen
suggestions of using an oil pressure switch to do this. But I am
thinking about changing it back to the factory system, which of course
means returning to a pump with its suction above the tank.(This is what
Wes Caughflin suggested); My question is whether those of you with the
original factory system are satisfied or do you have problems with vapor
lock or fuel pump priming causing problems starting engine. Larry.
