Emery,
I'll try your tactic the next time you fill up.
I wonder how do you know when the tanks are full. Do you wait
until the gas is all the way to the hose nozzle, or is there another cue?
I find that I can never put in more then about 30 gallons. I've tried to
go very slow at the end like you suggested, but since I don't have any
good cue as to where full is, I probably end up not filling anywhere
near the top. Once I filled it a lot more then normal and I could smell
gas inside the coach (my wife was worried that either we would catch
fire or the coach would never stop smelling like gas)
Richard Waters '76 PB, Troy, MI
> It is sometimes difficult to get a full tank in the GMC because of the tanks
> not venting properly. You are pouring a lot of fuel into the larger fill
> hose and the tanks are trying to vent out a very small hose (either 1/4" or
> 3/8"). You'll find that the gasoline filler nozzle will kick off at about
> 1/2 tank or so. Then you might have to stand there for about 5 or 10 minutes
> coaxing a small amount at a time until your tanks are full.
> A few months back I posted a suggestion that works for me. When pulling into
> the gas station, I lower my right air bags. This allows me to get in almost
> a full tank before the nozzle kicks off. I may have to coax in the last 5
> gallons or so. The only drawback is having to pump up the right rear airbags
> before leaving the station. However, this is much, much quicker than the
> time it used to take to fill my tank. By the way, this problem occurred even
> after I had replaced all my hoses going to the gas tanks.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
