We do have a double lip seal we provide for the outer seal.
Jeff Sirum and I have them in stock.
If your knuckle is loose, nothing will help.
Need to have a good rebuilt knuckle.
On Thu, Aug 29, 2019 at 9:40 AM Justin Brady via Gmclist <
> It's not that they are so great, it's that they are so easy lol.
> I can swap a whole front hub on my duramax in 15 minutes.
> They last about 80-100K miles for me. Even if they lasted 30-50 on the gmc
> the ability to swap one on the side of the road with nothing but a socket
> set is awesome.
> That being said I highly doubt it's that easy to make a sealed setup work
> without doing something similar to the 1 ton conversion.
> > As I have been posting in the past;
> > If you do the proper things, you can go 80-100,000 miles w/o greasing the
> > front.
> > Most that have not had the privilege of learning how to do that need to
> > check with us.
> > If One to bearings are so great, then why are they readily available
> > On Thu, Aug 29, 2019 at 9:07 AM Bruce Hislop via Gmclist <
> > > You can do the one-ton upgrade yourself if you have a local junk yard
> with
> > > a late 80's into 90's one ton 4wd GMC or Chev pickup with an
> un-damaged
> > > front end.
> > > Google GMC motorhome one ton front end upgrade.
> > > h
> > > Bruce Hislop
> > > ON Canada
> > > 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.1 ton front end
> > > My Staff says I never listen to them, or something like that
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
> > Jim Kanomata
> > Applied/GMC, Newark,CA
> > jimk
http://www.appliedgmc.com
> > 1-800-752-7502
> Justin Brady
http://www.thegmcrv.com/
> 1976 Palm Beach 455
