Put you finger next to the knuckle and drive axel ans see if there is any
play. If there is I can be 95% sure your Knuckle is worn.
We supply a rebuilt knuckle that will solve your problem, and if you need a
bearing puller, we rent them and give you 100% instruction to do it
properly.
On Wed, Sep 9, 2020 at 10:03 AM Jon Roche via Gmclist <
> I would worry now.
> hub should be pretty damn tight. now if you are mistaking the play for
> ball joints, that is a different discussion.
> it is usually the knuckle bore that goes to hell, bearings then the hub.
> most hubs are OK but still need to be carefully checked, bearings should
> be replaced when taken apart, but it is knuckle bore that is almost
> always out of spec, and you should get a rebuilt knuckle or have it checked
> by
> someone that is really experienced in GMC front ends.
> Jon Roche
> 75 palm beach
> EBL EFI, manny headers, Micro Level, rebuilt most of coach now.
> St. Cloud, MN
http://www.gmcrvparts.com
