I'm swapping out my clearance lights and got to the front and after removing the old lights discovered I don't have 12v on any of the wires up top. Fuses all look good. Ground wires are fine. Fuses are good. Rear clearance lights all have 12v.
I'd like to avoid taking down the front cap inside. Where do the roof clearance lights connect inside? I'm guessing they all connect to each other at some point before coming down to the fuse block. I must have a wire somewhere that's been cut.
