Front Battery Tray
donald w. miller
188
Terry,
(This thread has died but I forgot to mail this)
Believe it or not, I found room for two golf cart batteries and the engine
battery on the starboard side.
It's a tight fit and you will need a mirror and light to check the golf cart
electrolyte.
I made a new tray out of 1/4" aluminum which is bolted onto the old battery
tray brackets which are attached to the frame.
I bent some lips around the perimeter to keep the batteries from sliding.
The two golf cart batteries are next to the wheel well liner with start
battery in front.
Don Miller
75 Glennbrook project
Shenandoah Valley of Virginia
> I would like to move my household batteries forward to the engine
> compartment. Seems like the best place would be on the starboard side and
> move the engine battery to port under the steering column. The reason for
> the use of boat terms is so there will be no question as to which side I
an
> talking about. Has anyone done this? (what a dumb question) How did it
work?
> Do I need to run a new cable front to back? Should I consider a small 12v
> battery dedicated to the generator? In my mind it just seems to be better
to
> get some of the weight moved forward to counter balance all the "extras"
my
> wife keeps adding. 80 lbs and
> holding.....................................Terry
> PS I did read all the tire pressure e-mails and I didn't always agree, BUT
I
> wanted to hear everyone's opinion and use them to form mine. PLEASE don't
> stop writing in. Especially Arch. I value your opinion.
> Terry & Diane Skinner
> Webfooted in Washington
> '76 Glenbrook
