Did this law apply to modifying the brakes also ??
gene
>Bound to get into trouble for this one. I found out today that it is
>against the law, illegal, prohibited, frowned upon, jailable, close the
>door and throw away the key, in Alberta any way, to make any non-spec
>modifications to the front end of a vehicle. Drilling rotors or backing
>plates, shortening or lengthening axles, turning the steering shaft 180=BA
>to use the unworn side or any thing like this is strictly taboo. I don't
>know what the laws are elsewhere, but it makes me think it is not that
>different there.
>I was thinking of making the adapter from the rotor to the wheel
>shorter. Uh ooh. Not a chance. No one would touch it, because it is
>illegal to make ... You get the picture.
>For those of you who tried to tell me about the bearing loading and
>offset and other stuff, I figured it out today. Yes it definitely will
>increase the load on the bearings. For what I am doing, not a
>significant amount. I neglected to tell you that I am using an 8" wheel.
>The offset of the wheel is also 1.5" inboard. This will give me 5.5"
>inboard and 2.5" outboard. It does get the wheels more in track but
>still gives me more tire to the inside where it should be. I am still
>going to go ahead and am prepared to keep up the maintenance on the
>bearings. If I need to do them every 17 - 20 thousand miles, that's
>life. I would like to thank all of you for the time you all spent trying
>to convince me of the errors of my ways, but it did generate a lot of
>interesting discussion. The purpose of this group sometimes.
>Any one going to Idaho or Mt. Hood in September can quiz me on the
>outcome. I still really, really would like the new style NEEPER wheel I
>have been drooling over but at $450.00 a wheel it is pricey. Lets see,
>if I make 5% on my sales I can buy the NEEPERS in 2005. About the same
>time my new 9.50 x 16.5 tires wear out. Got to plan ahead.
>Keep up the good work people. Darren
> Darren Paget
> 76 Experimental
> Another Fab Day
http://www.TZEplus.com
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
