>Just back from our short trip to Ca. from AZ. ... any tips to
>improve engine& tranny temps? Thanks and keep on GMCing.
I have been very aggressive at keeping my operating temps low. I like to
run my engines at 160 degrees and do whatever it takes to keep them there.
You may or may not want to be that aggressive but here is how I did it...
1) Install Robertshaw 160 degree thermostat (P/N 330-160 I think).
2) Install a heavy duty fan clutch. If it still allows the operating temp
to go over 160 degrees (mine did) then adjust the thermostat on the fan
clutch. This can be done by making a new slot in the bracket that holds the
outer end of the thermostat coil and moving the fixed end of the coil to
the new slot. I adjusted mine so it starts to engage at 75 degrees outside
temp (with the dash A/C turned on).
3) Check your timing and the timing advance curves. If you still have the
older points style ignition, be sure its tuned up properly. The ignition on
our 73's all used the breaker point style distributor. If your engine has
electronic ignition then it has been upgraded and there is a good chance
that you may not have the correct distributor.
I learned that the timing curves are very critical. For years I had to use
premium gas to prevent knocking and have been struggling to keep my
operating temps down. Thanks to a lot of help from this list I checked the
timing curves on my distributor and found that I had the wrong vacuum
advance. The Toronado distributor I was using had a 27 degree vacuum
advance. After installing a new 10 degree vacuum advance (Delco 1973577) I
can now run regular gas and have solved the overheating problem. This
weekend was a good test of the cooling system. I was running through the
hills of Pennsylvania and the engine temp never exceeded 160 degrees, even
running uphill with full dash air.
I don't have any hard data to prove it but I suspect that the lower engine
temps probably keep the trans temps lower too. If I can find the time I
will be installing a trans temp gauge this summer so I can gather more facts.
Dave
73 Sequoia
Dave
73 Sequoia
