Kelly,
The more distance you have between the bottom opening and the top will
create a better draw of air.
Also the outer wall produces heat, so insulate it a little.
Also blank off the side openings as the air drawn through will be from the
outside ad ot from the inside.
We receive great review from the ladies as it cools well and not effected
by uneven parking.
We also have a low Delivered price o Norold units.
On Sun, Jul 14, 2019 at 4:52 PM kelly stockwell via Gmclist <
> Thank you, I can put the same thing in (my fridge is in now, compartment
> unmolested) but I'm thinking something other than the size of what's in
> there. Maybe the newer LP fridges are better than the old ones (my
> absorption fridge is at least 20 years old)
> can I push closer to the wall, get one for a boat with a cutout at the
> bottom, etc. I'm looking for the measurements of the coach so I can think
> ahead before I tear anything out
> Cheers
> kelly
> > Kelly,
> > That looks just like where I put a Dometic 2652 some 20 years ago. All
> the
> > dimensions are here:
https://www.dometic.com/en-us/us/products/food-and-beverage/mobile-refrigeration/rv-refrigerators/dometic-americana-dm-2652-_-31177
> > Ken H.
> > On Sun, Jul 14, 2019 at 6:28 PM kelly stockwell via Gmclist <
> > > I'm contemplating fridge options. I've changed burners, added vent
> fans,
> > > reinsulated, cleaned the flue, put in a new regulator.. It just
> doesn't do
> > > well when it's over 85 degrees outside (got to 54 yesterday)
> > > It's hard to read off the dimensions in the drawings that have been
> > > shared, what is the intrusion into the coach from the wheel liners
> shown in
> > > this
> > > attached photo?
> > > Specifically, how far into the coach does the wheel well reach, how
> high
> > > off the ground is it? I'm looking at possible under counter/top open
> fridge
> > > (danfoss compressor) and I'm wondering if I can put it in sideways.
http://www.gmcmhphotos.com/photos/member-galleries/p50431-img-0760.html
> > > thank you
> > > kelly
> > > 1978 Kingsley
> > > Putney VT
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
> 1978 Kingsley
> Putney VT
http://www.appliedgmc.com
