For the late 78 owners. Get the air filters out of both your air compressors.
Bob Dunahugh
2,784
4
3
Your 2, suspension air compressors each have foam air filters built into the compressor head. Due to age. They've become a sticky/flaky material that can cause your solenoid valves to leak air from the air bags. A Q tip, and a vacuum cleaner seems to work to get the very small filter material out. Use a 5/16th nut driver to remove the 7 small bolts. Lift off head. You will see the filter, or the rectangle hole that it did reside in. Haven't found a replacement filter material YET. But will notify when I find a replacement. At this point. No filter is better then what you have now. This late system is very simple. Compressor, start relay, solenoid valve, and an electronic eye. One set for each side. Bob Dunahugh Late 78 Royale
Bob I haven't seen the EL II pumps in person, but are they single piston like what GM used on E cars Riv/Toro/Eldo? These have a barbed inlet tube.
The Buick Turbo cars used an AC Delco 218-13 or GM 801528 foam filter on the wastegate solenoid to keep dirt out. It is a square foam about 1" long
and 3/8" in the square dimension with a hole to slip over the barbed inlet. They come in boxes of 10. I put one on the pump inlet on my Riv and it
fits perfectly. If there was one there originally it was long disintegrated. I have picture but rhey always exceed size restrictions here.
John Lebetski
Woodstock, IL
John,
Parts Book 78Z / Section 14 - Air Suspension / Pages 14 -16 through 14 - 20 have exploded views of both the single and dual cylinder
OEM air pumps.
Regards,
Rob M.
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of John R. Lebetski
Sent: Tuesday, August 8, 2017 12:15 AM
Subject: Re: [GMCnet] For the late 78 owners. Get the air filters out of both your air compressors.
barbed inlet tube.
foam about 1" long
my Riv and it
here.
John Lebetski
Woodstock, IL
John. Could you send that photo to me. Sounds like a better filter then stock. The compressor in the 78 GMC seems to have been installed into GM products to 2006. Maybe even new. And is still available at GM dealer now. It's a single cylinder compressor. One of mine will go to 175 PSI. I'll send you a photo. Bob Dunahugh 78 Royale
Sent: Sunday, August 6, 2017 8:58 PM
Subject: For the late 78 owners. Get the air filters out of both your air compressors.
This also applies to the Dana twin cylinder compressors. On those the filter is behind the inlet fittings. Same deteriorating foam. On mine one was
gooey the other was gone into the crankcase for each cylinder.
Steve Southworth
Palmyra WI
Steve,
John Clement has a new filter material that eliminates the problem of the
deteriorating foam filters.
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Monday, August 07, 2017 6:02 PM
To:
> one was
> Steve Southworth
> Palmyra WI
> Steve,
> Gary Kosier
Good to know. I ran hoses from my compressor to a homemade air filter tucked way up under the hood.
Steve Southworth
Palmyra WI
