Float Switches
slc
261
As I am always looking for a deal on what seem to be reliable parts, I have come across this
from one of the dealers that I frequent.
These are float switches for liquid, in our case potable water.
http://www.mpja.com/06-07-18.asp?r=00000&s=15
Detailed Description
Plastic float switch with reed switch contacts rated.
Max switching: 24VDC
Max Switching current: 0.05 Amp
Max carry current: 0.1 Amp
Max Contact resistance: 0.4 Ohm
Contacts normally open with float at the bottom rest as pictured .25" +-10% travel to activate reed switch. Wire Length: 12". Rated for water only!
H: 2" Dia: 3/4" WT: .04
Product ReviewsClick here to review this item
Plastic material
Does anyone know the type of plastic the float and body is made of? PVDF, PVC, ?
Control Engineer
Great little float switch
The float is held on by a plastic C clamp which can be removed, the float reduced and it will change from Normally Open to Normally Closed and vice
versa.
- Dale, TX
If you are trying to restore the operation of the OEM level guage, you can add a resistor to each level (size to be determined) and when the level
switch closes, the level would indicate on the meter. Or you can run to LEDs to indicate level.
Simple design and if you want fast access, you may install a top access in the tank and install these on some pvc. Just ideas.
Check it out.....
thx
GatsbysCruise. \
74GMC260 Former Glacier Model style. \
Located in Waukegan \ Keep those MiniDiscs Spinning \ MY GREYHOUND IS FASTER THAN YOUR HONOR ROLL STUDENT \ WindowsXP-Win7-Win8.1-UBUNTU STUDIO -
UBUNTU VOYAGER - Berzin Auto Center in Waukegan
