Fist major trip since rebuilder.
jim kanomata1
9,932
3
Be sure and flush the old brake fluid as the moisture will turn into steam
and end up with no brakes when things heat up
> What Johnny says. Better to pulse the brakes at higher pressure and shorter
> intervals than constant application.
> And as Bill states. Manny says tranny for go and brakes for stop. If the
> hill super long and steep and the brakes become over taxed you really ha e
> no other choice than to use the trans for engine braking. I would avoid
> that as a matter of habit but I’d rather use the trans to slow down than
> fly off a corner because my brakes have boiled.
> Sully
> 77 eleganza 2
> Bellevue
> > Manny rebuilt my trans and told me to be easy on it.
> > I live in the hills and cannot rely on brakes alone.
> > So I use a combination of driving slow downhill in 2nd gear
> > and also pumping the brakes. I never exceed 40MPH in 2nd.
> > So far, so good.
> > Best Regards
> > Bill Wevers GMC49ers, GMC Western States
> > 1975 Glenbrook - Manny Powerdrive, OneTon
> > 455 F Block, G heads
> > San Jose
http://www.appliedgmc.com
Also use DOT 4 brake fluid when you flush it. ($5.00 a quart at Walmart) It is compatible with the DOT 3 that you probably already have in the
system but boils at a higher temperature. There are other fluids the boil at even higher temps but for now DOT 4 is better than DOT 3 and is
backwards compatible. DO NOT USE DOT 5.
One thing I do is to remove the brake fluid with a turkey baster every oil change and refill with new.
Not as good as bleeding but a lot easier and helps keep the moisture at bay.
The old knowledge still applies here. Oil floats on top of water. Or brake
fluid for that matter. So, the water winds up in the calipers, and wheel
cylinders. Bleeding the system is the only reliable way to get it out of
there. Every couple of years in normal humidity, more often in high
humidity.
Salem, Or
78 GMC ROYALE 403
> bay.
Brake fluid will adsorb an amazing amount of water. However when heated the water will vaporize and cause brake failure as it compresses. So, as Jim points out the only solution is to bleed the brakes and replace the fluid with new.
Emery Stora
77 Kingsley
Frederick, CO
> humidity.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
>> bay.
>> GMCnet mailing list
Jim,
Glycol-ether (DOT 3, 4, and 5.1) brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the
atmosphere under normal humidity levels. Therefore it's best to replace it regularly.
I use ATE brake fluid from Germany which as far a I have been able to find has the highest dry and wet boiling points of all the
fluids available. They say theirs is good for three years.
http://www.ate-brakes.com/products/brake-fluids/
BTW if a GMC owner has one of those neat pressure bleeders made by some guy up in Oregon, it's a piece of cake!
http://www.gmcmotorhomemarketplace.com/jhupy/
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of James Hupy
Sent: Wednesday, April 18, 2018 3:02 PM
Subject: Re: [GMCnet] Fist major trip since rebuilder.
humidity.
Salem, Or
78 GMC ROYALE 403
Thanks for the plug, Rob. Personal experience with brake fluid here in wet,
rainy, Oregon has taught me to change it more often than what GMC says.
Houston area with high humidity should be similar. The old colored dot 3
sure was handy for flushing systems.
Sorry to have missed the Tuscon rally. Lot of people there I wanted to
see.
Salem, Or
> Jim,
> regularly.
> Regards,
> Rob M.
> Sydney, Australia
> Hupy
> To: gmclist
> humidity.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
To Jim H.:
And a lot of us that wanted to see/meet you. Maybe next GMCMI event In Iowa in fall?
Mike/The Corvair a holic
Sent from my iPhone
> Emery Stora
> 77 Kingsley
> Frederick, CO
>> humidity.
>> Jim Hupy
>> Salem, Or
>> 78 GMC ROYALE 403
>>> bay.
>>> GMCnet mailing list
>> GMCnet mailing list
You're welcome!
Yep, another demonstration of government incompetence; they made the Blue ATE fluid illegal to sell because it looked like silicone
base brake fluid (it's purple) because people might be confused THEN created DOT 5.1 which is glycol based - NO ONE would confuse
that as being compatible with DOT 5 - WOULD THEY? NAH!
Regards,
Rob M.
Sydney, Australia
Sent: Wednesday, April 18, 2018 3:33 PM
see.
Salem, Or
Where do you think all of that recalled Blue ATE went? I heard Canada.
Don't know. Sure was handy when flushing systems though. What color is
aircraft fluid these days, is it dot 3 or dot 4?
Salem, Or.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Sixteen 1 litre cans wound up in my storage unit in Houston. :-)
Regards,
Rob M.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ken Burton
Sent: Thursday, April 19, 2018 8:31 AM
> Hey Rob
> this must be a US thing seems we can get green dot 4 from Valvoline here
> https://www.valvoline.com/en-australia/our-products/performance-chemicals/valvoline-super-performance-dot-4-brake-fluid
Trevor,
It is a US DOT thing.
Some bespectacled bureaucrat decided that DOT 4 shall only be one color.
So, that is all that is allowed here.
The truly great part is that while different colors for different types are required, there is no required color difference between DOT5 and DOT5.1.
DOT5 is synthetic and DOT5.1 is just a higher temperature version of the old stuff and the two are completely in-compatible.
> Jim Hupy
> Salem, Or.
Aircraft brakes usually use MIL spec 5606A or 5606H hydraulic fluid. 5606H is suppose to be cleaner. It is red and not similar to DOT the stuff. I
have not investigated what it really is, but I have read that one is mineral based (petroleum) and the other is vegetable based. I have heard of
people using Dexron III in aircraft brakes. I do not think the FAA approves of it's use. I have a gallon can of it that I have had for years. It
does not attract water like the DOT stuff so we seldom flush the systems. It does not peel paint like the DOT stuff. Small aircraft do not use
brakes much so we seldom work on them.
Large aircraft with heavy braking loads could be an entirely different story,
