Have an assistant step on the brakes to see if the rear bulbs are good. Try
either/both turn signals and see if the bulbs light. Check the bulb sockets
as well as the bulbs. They can be corroded. Replace suspect bulbs and the
flasher. They are expendable.
> depending on the type of directional signal blinker relay, the signal
> lights will not blink if there is a burn't out bulb. Turn on the direction
> signal in one direction and take a walk-around the coach to see if the
> signal lights are ON. Then try the other direction and check that side.
> May also be a faulty directional signal blinker, they are a common item.
> Do your 4way flashers work?
> Bruce Hislop
> ON Canada
> 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.1 ton front end
> http://www.gmcmhphotos.com/photos/showphoto.php?photo=29001
> My Staff says I never listen to them, or something like that
> Bruce Hislop
> ON Canada
