First experience with Progressive Roadside "Assistance
LQQKatJon
3,226
547
113
St. Cloud, Mn
lqqkatjon.blogspot.com
I use Aaa, and have good luck. But not all coverage is the same. Mn Aaa is different then alabama aaa.
From years of talking and reading about everybody's different coverage, i have come to the conclusion it is all about Luck and LOcATION! Even if
you have good coverage, luck may or may not be on your side when the tow truck shows up. Gmc is not complicated to tow, but sometimes they just
can't figure it out. I have been on the side of the road and on the end of a tow truck i. Less then an hour. Others I have seen days or weeks to
get the right tow truck and driver out.
Good luck.
On the note of your gmc. 90% of time what you describe will best to buy 3-4 carb fuel filters. Change that out and drive it again. I think 1"
ans 5/8" wrench. As well as 3/8 or 7/16" socket. Take carb loose to help get the fuel line in and out without cross threading. There are photos
or send me your email address and can easily walk you through that process. I think you can limp it home with a new filter. Either way, that is
first thing to try to troubleshoot. Having an unknown age of filter, you have to start with a good filter.
Jon Roche
75 palm beach
St. Cloud, MN
If you were not the one to install that filter, you have to check.
There is a possibility of other filters that were installed in the last 40 years that could also be a problem. I have seen old filters in new carbs
before. Have seem some odd stuff done by "good" mechanics. All fine, until you brake down. Then back to the start and troubleshoot from
beginning. Make sure you have gas too.
Jon Roche
75 palm beach
St. Cloud, MN
> Yikes.
> Thanks for that tip about the carb filters. We know it has a new carburetor, so hopefully new filter.
Cartgal,
It is also very possible that if the coach was recently revived that the new fuel in the tank stirred up the old junk and the filter in the carburetor
is already toast. Buy several and carry the tools to change it.
In the mean time,
Welcome to the group, family, cult, asylum....
Please do us and yourself a big favor. Go to and scroll down to where you can fill in a sigfile. Put in a real
name, so when you need help (again), we will know who we are talking to. Add a bit about the coach, year and model do matter as there are some
critical changes. Please include any major mods as that may matter too. A geographic reference is also good and part of that will be explained
next.
This is a wonderful community of helping and supportive people that all have a non-hidden agenda. That is that we want to see you get to enjoy both
your coach and what it can do for you. It is much more than a new toy, it connects you to this community. The support you can get here is the stuff
of good news stories on the web, but this is real. It reminds me so much of the watermen of my world that I like to welcome new owners as you might
be welcomed there. I missed this when you first appeared because I was answering with my phone. So here goes,
May the Good Lord bless this coach and all those that set forth within her.
Welcome Cartgal(?)
Carrying more than two filters is not what I like as one can end up with
old beat up filters that might sit arond for few years.
Great idea to cary the esential tools needed to undo the fitting and
housing and the 1/2" socket to undo the carb and slide it back 1/2" to ease
the removal and installation of the filter.
> > Yikes.
> Cartgal,
> carburetor
> In the mean time,
> Please do us and yourself a big favor. Go to Settings> and scroll down to where you can fill in a sigfile. Put in a real
> next.
> her.
> Welcome Cartgal(?)
> Matt
http://www.appliedgmc.com
> Matt,
> Thanks for your helpful reply. I will do that.
> We were just having a conversation about whether the old gas had possibly separated. I can tell you, my husband was so bummed about it all, that
> he was regretting buying it.
> We stopped by the Dixieland rally the day before our purchase and met a bunch of great people.
Frances,
Many of us have early problems with coaches. Please do not let your husband get discouraged, when he gets her right, you will understand why the rest
of us are addicted to them. It may be that the problem you have seen was the same that many others have had. (This is almost a sucker bet.) But
being ready to deal with that (and the ignition problems if you have HEI) will just add character to the coach.
That filter is really easy to change out.
Loosen the nut on the line while holding the hex on the body.
Loosen the filter body on the carburetor. Use a BIG adjustable wrench and be careful.
Undue the four fasteners that hold the carburetor to the manifold.
Gently walk the carburetor back while loosening the fuel line.
When you can, finish unscrewing the filter housing.
As you remove things, there is the filter and a spring.
**Pay attention** The filter direction and the spring are critical.
Replace the filter and spring and start the housing in with FINGERS....
**This is a very fine thread piece and easily damaged and impossible to repair.**
When fingers are done, put the carburetor back in place, get the fuel line started and then tighten the carburetor to the intake.
Now tighten the filter housing and the fuel line.
Start the engine and check for leaks.
Can you tell we have all done this a couple of times???
Enjoy the journey.
Oh, those nice people you met at Dixielanders, you now have about a thousand other new old friends..
Try to make the Spring International at Tallahassee. You will meet more.
Frances welcome. At the top right of the page, next to your login, you will see the Control Panel link. Click it.
Now, click the Account Settings link.
At he bottom you will see Preferences Open it and you will be able to fill your Signature.
I suggest you also check the other Account Settings while you are there.
Patti & Jerry Burt Fresno, CA.
73 Gmc 26' Canyon Lands -
77 Palm Beach
Members: FMCA - GMCMI - GMCWS - 49ers
A truly happy person is one who can enjoy the scenery on a detour.
