finding water - Backwards blower!
john dolan
503
Dick...
Unless this was a fluke, I wonder how many folks with poor cooling/air
movement were suffering from the same malady as your blower. If you cut
off the connector that could not be reversed, and reconnected it it might
be a good backup, no? Mine always seem to develop a whine after a while.
>You mention the heater fan. My question is this. I could not get heater
>to go into the high speed mode------only had 3 speeds. Put in new high
>speed and solved that problem. But even at high speed there is not much
>air
Some times those blowers only go into high when the air circulation lever
is on MAX or Recirculate, why I don't know...
Regards,
John Dolan K3FIG
74 Glacier near Washington, DC
>John
>The high speed relay also will not let it come on unless the motor
>is running. Take Care Arch 76GB IL
Are we talking about the same thing, Arch?
I'm talking about some GMC ACs that I have had, where if you switch on
the engine, then the AC, then the blower switch to the highest position,
it is still not at its highest speed till you move the Air Circulation
lever to MAX.
Regards,
John Dolan K3FIG
