You can get the 3.55 all set up from Buskirks. I have had a 3.55 final
since Oct. of last year and have 6000 miles with no noise or problems.
Made a big difference in the mountains and hills and when towing.
J.R. Wright
GMC GreatLaker
Michigan
> I am ready to order a lower ratio final drive. The questions is which one to
> put in. Cinnabar has a 3.42, Applied Air Filters and Gearmaster (Marvin
> Peck) are advertising in Motorhome Marketplace drives that are 3.55 and 3.67.
> I lean toward the 3.42 only because I think that its 11.4% increase should be
> more than adequate based on my use of the 3.07 the last 18 years. Also, I
> feel it very likely that Cinnabar will be around for a long time.
> I don't know anything about Applied Air Filters and their gears.
> I have had no experience with Gearmaster but it would be a much lower gear
> ratio. About a 20% increase.
> Using the info that some posted about RPM at 60 mph being approx. 2300 rpm,
> this would give the following for the ratios 3.07, 3.42 and 3.67: 2300,
> 2562 and 2750. At 70 mph the rpms would go to 2683, 2989 and 3208.
> Since I do much of my driving toward the 70 mph on highways I think that the
> 3.67 might be a bit too much.
> Does anyone have a plot of the power/torque curves? I believe someone said
> that it is about 2800 rpm where they both peak.
> I don't want to analyze this to death but I have to live with my choice.
> BTW while searching the net I came across a large transmission/differential
> distributor that carries several of the major lines. They specialize in
> rebuilding and supplying gears for differentials. I called and talked to
> someone there who said he was familiar with the 3.42 setup and said that
> these higher ratios were not GM parts but were privately developed by others.
> He said the 3.42 was only available from someone in Michigan [ Cinnabar,
> obviously]. He also said that there apparently was someone in Texas that had
> an even higher gear [ must be Marvin Peck].
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
J.R. Wright
GMC GreatLaker
Michigan
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
