Question: How can I tell the ratio of my final drive? My 26' '76 weighs
11,700# loaded and I seem to have adequate power on hills (except at high
altitude, of course), but would be curious to know if I have the original
3.07 gears. If so, switching to Caspro's 3.50 setup might make everything
(power, temperature & mileage) even better. Is there an easy way to tell if
my coach's final drive has been modified?
Suggestion: Keeping the fresh water system healthy is a constant problem.
Impurities are introduced every time the tank is filled. We do a thorough
sytem purification once a year, but in the interim are never sure what's in
the system. An easy way to insure safe water for cooking & drinking is to
use a portable purifier, like a Brita, Ecowater or Glacier Pure. They're
1/2 gallon carafe types and cost about $20. The filters aren't that much
since the filtered water is only used for drinking & cooking. ps: If the
regular pitcher doesn't hold enough, just keep some plastic bottles full of
filtered water in the frig.
Of course there's also the counter-top and under-the-counter types if
you're into plumbing and/or spending a little more $.
Regards and TIA, Dave
