Fan Shroud; Alternator bracket now headliner problems
richard waters
1,236
Gene,
I might just do that. Apply the stuff with a roller. Thanks for the
tip.
Richard
> Richard
> I used a paint roller to apply my contact cement onto masonite when I put
> up my headliner.stuck the material up while the cement was still wet. Worked
> pretty good.
> Gene
> 73 Glacier
Sounds good. Thanks for the input. BTW what adhesive would you
recommend? It should be high temperature because if I go to all
this trouble I want it to stick!
Richard Waters
> Richard; Here's annother technique to apply covering to a flat surface
> without getting wrinkles:
> 1) Lay the covering material onto the paneling exactly where you want it to
> stay.
> 2) Cover 2/3 of the covering with plywood and add some weight to hold it in
> place.
> 3) Fold back the exposed 1/3 and apply adhesive to the underside of the
> covering material and the paneling.
> 4) Carefully lay the covering material onto the panel, pulling gently
> against the covered portion to keep the material flat.
> 5) Use a rolling pin to insure good bond.
> 6) Remove weights and plywood, and fold remaining 2/3 of covering back over
> glued 1/3.
> 7) Apply adhesive to 1/2 of remaining covering and paneling.
> 8) Lay covering onto middle 1/3 of paneling, again pulling to keep material
> flat, and roll to insure good bond.
> 9) Fold remaining 1/3 back over glued portion and apply adhesive.
> 10) Lay last 1/3 onto paneling and roll to insure good bond.
> HTH
> ___________
> Dave (& Dege), '76 Royale /_][__] [_] | "SR JAMES"
> Santa Barbara, CA *0-------OO--* (our hobby)
stay.
place.
glued 1/3.
HTH
___________
