Exhaust donut needed
Keith V
3,583
377
83
I'm having an exhaust leak in the donut between the header and the exhaust pipe. Its stinking up my coach.
I'm on the road in south dakota.
I tried O Rileys, but they can only look up by vehicle.
Anyone have an idea where to get one on the fly?
Thanks!
Keith vasilakes
1975 Royale
I90 sioux falls South Dakota
Try Ols Toronado 76 455
On Fri, May 29, 2020 at 7:38 PM Keith V via Gmclist
> Thanks!
> Keith vasilakes
> 1975 Royale
http://www.gmcrvparts.com
Bring it in with you. I found them at NAPA.
Emery Stora
> Thanks!
> Keith vasilakes
> 1975 Royale
The exhaust donut that you want for headers is the FelPro 60584, Napa uses the same number as well as AutoZone too and that is the one that I use. You want the one that is for the Chevy truck GM V8 350 thru 454, 2 1/2” steel sleeve. Expect to pay between $9 & $12+. If they are the lower priced stuff at $4 to $6 they are probably the inferior quality stuff and you will be replacing it again in a couple of years. Important to get the best as of the high heat at that joint. Most Muffler shops also stock the good donut too. As had be said take your old one for size comparison. Be sure to clean the header pipe bell mouth to the muffler mounting flange with some scotch bright to remove any carbon buildup. If you use the bolt and spring arrangement to hold the header and downpipe together, the Dorman Help line at most autoparts stores is GM1900-71 part number and again take your old parts for comparison.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> Emery Stora
>> Thanks!
>> Keith vasilakes
>> 1975 Royale
>> GMCnet mailing list
FelPro 60584
Amazon $7.79
I took an old one to Advance and they matched it. Been a while, unfortunately don't have the envelope with the part # any more, but it waqs a stock
item.
--johnny
Braselton, Ga.
Wow what an awesome response! I cant bri g the old one in because i dont have towed, and im not driving it without a gasket!
Ill call around and see if i can locate one?
GMC guys are the best!
Keith
Sent: Friday, May 29, 2020 10:40:30 PM
Cc: John Wright
Subject: Re: [GMCnet] Exhaust donut needed
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
Michigan
> Emery Stora
>> Thanks!
>> Keith vasilakes
>> 1975 Royale
>> GMCnet mailing list
I use the 60241, which Fel-Pro's website shows for an Oldsmobile 403/455 application. I haven't used a 60258, which crosses with a Chevy 350/454
application. Fel-Pro's website shows a slight size difference between the two. I may grab a 60258 today and see what the difference in fit is, if any.
Norman, OK / August 1977 Kingsley / 403 / 3.55 / 16" / Quadrajet
And now I see you have headers, rather than manifolds. My answer was regarding manifolds.
Safe travels,
Ty
I got the donut in it fits, not sure if the 241 is better or not, but this one worked.
Its nice not go have exhaust fumes in the coach.
Btw, how we found it was i put my wind wing all the way out, this sucks air out of the coach pulling exhaust fumes in. Hard to believe that can happen at 6p mph, but it was sure repeatable!
Sent: Saturday, May 30, 2020 10:50:56 AM
Cc: Ty Hardiman
That must be the difference
Sent: Saturday, May 30, 2020 10:53:17 AM
Cc: Ty Hardiman
Safe travels,
Ty
Furthermore I see that I mis-typed JR‘s recommendation, which he correctly stated was the 60584 for the Chevy 350/454. Guess I should’ve had
another cup of coffee before I started posting this morning.
More coffee is always the right answer!
Sent: Saturday, May 30, 2020 9:09:39 PM
Cc: Ty Hardiman
There is a distinction between Manifold and Headers.
Be specific as it is rude to say one and mean another.
Since I spend about 60% of my time answering tech questions and being 77
I’m not too toleren .😩
On Sun, May 31, 2020 at 10:11 AM Keith V via Gmclist <
> From: Gmclist on behalf of Ty Hardiman
> via Gmclist
> To: gmclist
> Cc: Ty Hardiman
What Jim is saying
Maybe. Is there is not usually a doughtnut with headers. Fairly certain you have headers if I remember??
Might need a closer look. I learned there was no doughnuts for my headers last year. Ended up a cheap
Muffler failed. Had to get under to see when I dived in to make sure bolts holding exhaust to header was tight.
Jon Roche
75 palm beach
St. Cloud, MN
The NEW design does not have donut, but the older headers use the donut.
On Sun, May 31, 2020 at 5:17 PM Jon Roche via Gmclist <
> What Jim is saying
> Jon Roche
> 75 palm beach
> St. Cloud, MN
I have old headers, Probably 12- 15 years old, the donut was the solution.
Donuts and coffee mmmmmm
From: Gmclist on behalf of Jim Kanomata via Gmclist
Sent: Sunday, May 31, 2020 7:28 PM
Cc: Jim Kanomata
> What Jim is saying
> Jon Roche
> 75 palm beach
> St. Cloud, MN
My Thorley headers have donuts.
Emery Stora
> To: gmclist
> Cc: Jim Kanomata
>> What Jim is saying
>> Jon Roche
>> 75 palm beach
>> St. Cloud, MN
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
