Lanier
Don't even think of removing the Head to remove a broken Exhaust bolt.
Megabuck kill of a simple job. Use lots of penetrating oil & drill the
bolt out. The center bolt does in deed go into a blind hole & several
application of Liquid Wrench will aid in removing the bolt. The use of a
small drill bit & a easy-out should do the job. If you develop a exhaust
leak it will act like a cutting touch & damage the head surface & make it
difficult (if not impossible) to get a seal in the future. Fix it now &
save, save, save !!!!!!!
Duane of Orange CA
Duane of Orange CA
